TB 102.2.2 (64 BIT) Look and feel via .css
recently, today, updated to TB 102.2.2.
when I first installed TB, I set up a custom color scheme and I loved it... now with the latest TB , it's unreadable where the top menu bar is concerned.
I also have custom userChrome css file....
- threadTree > treechildren {
font-size: 16pt !important; font-family: Times !important; background-color: lightgrey !important; color: navy !important;
- folderTree > treechildren {
would appreciate any insights on how to fix this
Modified
ok.. found a solution
The color scheme/theme I had pre-102.2 was called Two little birds. after the install I got the display as I showed in my attached pic. This was the dark Theme.. no idea why that showed up.
I went into: Account Settings/Add on and Themes and disabled the Dark Theme and re-enabled the Two little Birds theme..
issue resolved :)
